2000 Ficht Head Replacement
czimmel
Last fall I had a plug come out hard with shavings on the threads. I'm told by the shop that the head needs to be replaced. I was thinking heli-coil but they say that is not an option as it is only a bandaid. Wondering if anyone has an opinion on that? Head job is gonna run me a $1000 so the next question is how tuff of a job would that be to do myself? I'm pretty mechanicly inclined but I don't have any specialized tools.
Any help would be appreciated.
boobie
Band aid my butt. I've heli-coiled a lot of spark plug holes and they always worked fine. That shop is trying to put the screws to you. If you get the kit and follow the instructions, it's easy. And you don't have to pull the head off to do it. Just use some grease on the tap to catch the shavings.
hondam
A heli coil is a band aid and the best solution would be replacing the head. There is a lot of times people have to choose what will work vs the right way to do it because of the budget theres nothing wrong with that just what we need to do sometimes.
If you choose to change the head on your own make sure you do not mix up the injectors and put them back in the exact same cylinder they came off of. If you mix them up you will probably blow up your motor. They are flow tested and serialized and that information is programmed into the computer for each individual injector, if you start mixing them up the computer will have no idea how much fuel it is injecting into the cylinder.
Also make sure you index your plugs, If the head is pinned the electrode faces away from the injector, if its not pinned the electrode will face towards the injector.
boobie
I'll stick to what I said !!!!! And beside that, a heli-coil thread is stronger than the original. .
schematic
A properly installed heli-coil is actually stonger than bare aluminum threads
czimmel
What exactly does it mean to have the head "pinned"? I've been seeing that term used a lot.
boobie
There is a pin in the head that breaks up the spray from the injector that makes for better combustion.
max62
The "pin" also prevents direct oil/fuel spray from hitting the plug tip, which would foul it up quicker.
Honorary Supreme Mariner
Max62----Does the the injector spray just gas or a gas / oil mix on these motors ???????
Faztbullet
It sprays gas with a small metered amount of oil in it. What hp as there are a ton of used ficht parts for sale.
Chris1956
I have used a solid spark plug insert with good results. They are available in different reaches and diameters.
