2000 ficht 90 hp tilts down but not up
Sweeny Doug
I have checked both switches & all relays are good. I can swap the green & blue wires and it will tilt up with the down button. Checked the PDP for bad solder joints, but everything looked good. I’m at a brick wall. Any help would be greatly appreciated. TIA !!!
Joe Reeves
The electric motor is a dual polarity motor, meaning that if it works in one direction, it'll work in the opposite direction as you've found out by switching the wires.
I understand the tests you've made... BUT... if you did not switch the position of the relays... do so (humor me). If the problem now changes to the opposite, one of the relays is bad.
If the problem remains the same, then indeed the relays are okay and the problem would be that either both switches are faulty (Not Likely, but possible) or for some reason 12v is not reaching "OR" completing its circuit through the up relay..... broken wire, corrosion, something of that nature.
Sweeny Doug
I actually replaced the switch on the motor , and have tested the old one with an ohm meter, tested fine. I swapped out the relays with one another, numerous times & I’m still ending up with the same results. 12v are reaching the 2 main wires on the right side of the motor, but not to the switch on the motor or console. The up button on the console & motor have no power on the up (blue) side. I can fix anything from a model A to an airplane, but this thing is eating my lunch. I actually found, what appeared to be a faulty solder joint on PDP , re-soldered it , but it made no changes. I’m at a total loss. Ready to scuttle this thing, lol
jakedaawg
I would suggest isolating and ohm checking the blue w/white stripe wires wherever you can access their ends. One is obviously broke
Sweeny Doug
I did away with the limit switch, thinking the same thing. I’m still fighting the problem. My guess is a broken or corroded wire. Time to unwrap the harness and start hunting. I’ll post again once I get it apart. Thanks for all the ideas !!
