2000 Evinrude 225 with standard RH lower. E225FPXSS SERIAL# G04856253
Yesterday my lower unit decided to give out a bit. Heard/felt a vibration and as I slowed the vibration and noise got worse. Headed home on 1 motor. Firing up the motor on hose in neutral, you can feel and hear the vibration at the bullet. Also there is a fine vibration (like bad bearings) when I turn the prop by hand.
Everything still works - but is noisy and vibrates, thus I don't know the extent of damage.
I have heard the OEM lowers on these were weak. Not 100% sure if this lower had ever been rebuilt by previous owner, but I think it was. I also heard the rebuild parts are now good quality.
My question is: rebuild or replace lower with an SEI replacement?
http://www.sterndrive.cc/mm5/merchant.mvc?Screen=PROD&Product_Code=90-306-B&Category_Code=JohnsonEvinrudeLowerUnit
I have read good and bad about either direction. I gotta say, not having to wait for rebuild process, easy direct bolt up and a 3 year warranty looks GREAT to me right now.
So what you guys think?
