2000 Evinrude 225 Flywheel
Queseyo
Need a flywheel for a 2000 E225FPXSSC, part# 586539, has a casting #345365. Can't find 586539 on salvage market but see many 586422, it also shows casting #345365 but is listed as a 1999 part. A dealer told me they are not interchangeable, they look exactly the same. Is there a difference? Thanks
Faztbullet
If the 1999 is off a carb motor it will work, it will not if a Ficht
Queseyo
Thank you Faztbullet for the reply....I'm confused by the answer. Mine is a Ficht engine, I'd assume it would be matched with a ficht flywheel, not one off a carbed motor. The ones (586422) I've seen look exactly the same as my damaged one, I don't understand what could be different? The magnets look the same, the casting is the same, etc. What else??
Rustywrench
The ignition system is different. The 2000 has an EMM (Engine Managment Module) & the 1999 has an ECU (Engine Control Unit). If you take a screw driver you can feel three magnetic pulls in the 2000 (each magnet North South North) vs on two in a 1999. Hope that helps. Yes they look identical.
Some of these flywheels may have a place to bolt on a pulley for power steering.----That gives it a different part number.-----Consult a shop for an opinion on the detail.
Queseyo
That's exactly what I was looking for...now to find an '00. Seems odd I can find lots of '99s but no '00s. I've missed a lot of fishing!
Rustywrench
You might try eBay? Specifically Pine Lake Parts, Plainwell, MI or South Central Outboards, Beecher City, IL.
Queseyo
Thanks. Been looking on eBay for some time, saw a '00 back in March. Seen nothing since. Pine Lake and So Central don't have. Why aren't these motors going into salvage? Maybe I need to part this one out, haha! Starter is new, EMM reprogrammed, new thermostats, impeller, harness,TPS, only 800 hrs, would like to get it going.
Rustywrench
Jay's Block Shop has one! (931) 808-0814. Give him a call. 250. Hope that helps. What happened to yours? Haven't seen much trouble with those.
Queseyo
Long, sad story, bad starter did it in.. I'll give him a call tomorrow. Thanks
Rustywrench
Be sure you have your model number at the time. Suffix & all. Even a picture of the flywheel? There were H models & C models. Two totally different animals. Did by any chance the teeth on your old flywheel get tore off? If that motor fires out of time while cranking the flywheel teeth pay the price. Talk with Jay about it. He can fill you in.
Faztbullet
I got a 1999 also no 2000. Rusty did you get rid of all the Ficht stuff???
Rustywrench
It's GONE to Pine Lake & South Central, but may not have been a 2000 in that stuff. Those H flywheels are few & far between. Hope he doesn't have one of those. Jay thinks he has both. Hope his EMM is mapped for the right flywheel (what he had)! That might be what started all this. Jay will help him figure it out.
Queseyo
It's a "C" flywheel, Jay is looking. I guess if you don't know for sure what it came off of you use the the screwdriver test you described above?
Rustywrench
Just talking to Jay. We are figuring for you. The problem was some dressed powerhead got done which could have changed yours to an H type flywheel set up. The motors take two different maps (programming of the EMM) Also the upper main is different & sensor is mounted different. Just causes some pause when figuring out over the phone. If you are looking at it in person no problem. I'm sure he is asking you for clarifications right now. Then depending on what you have you have to make sure your programmed coerctly. I hope you already are. I can see the teeth on your flywheel. Suspect? Was the motor starting like it was out of time? Bucking etc.?
