2000 Evinrude 115 Ficht (fuel injected)
Rgrhunter
Hello everyone, I am new to the site. Recently purchased a 2000 Triton that has a 2000 Evinrude 115 outboard on it that is giving me grief. First startup was a little rough and boat lagged at mid throttle for awhile until warmed up and then went away. I took it out a second day with no real issues. On my third trip out hadn't realized realized the kill lanyard was removed so tried for awhile to get boat to run before retrailering it and taking it home. I changed out the spark plugs gapping and indexing them. Boat motor only has 47 hours on it, very lightly used and kept indoors in a storage facility. After plugs still couldn't get the boat to run unless I primed the fuel bulb. So i changed the fuel bulb and the fuel line at transom as well as the fuel filter. Boat still refuses to idle unless I squeeze the primer bulb. I hooked a pressure gauge up to the schrater valve and have no pressure with key on. If i prime the bulb and start the engine I can only manually pump it up to 20 and then it will slowly decrease until engine dies out. I can hear no noise from pump with key on, I have checked all of the fuses on the motor and under the dash. Big change from boat running and not running between 2nd and 3rd trip out was a fresh tank of fuel as well as a can of seafood. Originally I had thought i may have stirred some sediment up from the bottom. If i pump primer bulb up stiff and let it sit after about 5 minutes it gets soft again and requires pumping again. I have removed the middle section of boat to access the fuel tank, fuel line from tank to bulb looks in good shape. Any suggestions on other checks I can do to rule out the fuel pump being dead or not?
Faztbullet
Wont run without fuel pump working...check fuse,PDP panel and power to pump.Either a ECM problem or pump which neither is cheap...
Rgrhunter
I have looked at fuses and PDP panel, this evening I am going to ensure the pump is getting power. Such low hours on motor hard to believe pump is out.
Faztbullet
Its not the pumps fault it the ethanol in fuel swells internal componets...also check the lift pump its sat a while.
