markernineteen
Thread starter- Joined
- Feb 21, 2007
- 48
This problem has gotten progressively worse especially in rough water. I have the shop manual and I've checked the manual tilt valve , bled the system and checked for electrical malfunction .I've disassembled the unit and everything looks perfect ! I bought this boat/motor used and from the looks of the tilt lock it has been trailered with the motor tilted and unsupported , could this be a factor? Is it possible the absorber piston on the tilt rod leaks internally ? Thanks very much for your help !
