2000 90HP missing on one cylinder
dlippert
I have a 2000 90 HP Mercury engine I just bought on a used Boston Whaler.. Records show about 200 hours on it .. Compression and general shap are OK
Took it to local Merc dealer for tune up , leg oil change and new impeller.
They have had it 10 days trying to solve a cylinder that misses.
They stripped down carb and cleaned, order a new electronic module,, still stumbling.
Can someone give some insite for me to pass on to them, or should I take engine to another dealer..?
thanks
Drew
achris
More fish than mountain goat
Re: 2000 90HP missing on one cylinder
They are a very simple engine... Find out if the problem is a loss of spark....
Chris.......
4JawChuck
Easy enough to swap coils from cylinder to cylinder to check em, I find a lot of these motors have one or more coils replaced at some point. Usually because someone cranked the motor excessively without grounding the plug which shorts the coil internally.
Always ground your plugs!;)
