2000 90hp Johnson wont keep running
jimw59
My Johnson 90 would not run at all. Have jumped the starter terminals and now fires but will not run past the initial fire. Have hose directly in portable fuel jug with new fuel and checked all lines for blockage. Bulb is hard and does not go soft. Carb cleaner? oh, had trim tilt pump replaced this winter, but they did not start motor at that time.
jakedaawg
COmpression test, spark test with open air gap spark tester. Model number.
