2000 70 johnson water in bottom cylinder
jjrreb23
dont know history of motor someone brought it to me to tune up ,lol been ran real hot water pump melted and some of the houseing also fixed that. now can not find out where the water is coming from .all gaskets look good and compression. thinking crack in power head but i know its rare.
2mate
Re: 2000 70 johnson water in bottom cylinder
Could be the oil seal? Have you checked the exhaust housing gaskets?
jjrreb23
as oil seal are you saying bottom crank? and the exhaust houseing on this thing is only a plate as i can see it .if you are talking of the big plate on side of power head? but yes they seem to look fine nutin visible.
2mate
Yes the bottom of the crank seal,also could be a head gasket issue.
jjrreb23
hate to sound fool , does the bottom crank and seal get water near it ? reason i ask looks like it dont but im sure im wrong.. head gasket looked good and had 124 comp on it before i took it off. i now have power head off .crank seal was not milky dont know if that helps
jjrreb23
just pulled crank seal water did come out and seal looks to be 2 sizes to big for the grove could this be what i been looking for??? but i dont understand how water gets in the block from that seal.the seal im speaking of is the o ring on the crank seal houseing
jjrreb23
thanks 2mate it was a crack in power head.
