2000 7.4L Bravo III milky oil
Nippy273
2000 mercruiser 7.4l MPI fresh water cooled was running hot. I cleaned the risers, changed the thermostat and replaced the raw water impeller. The impeller was definitely a problem it was missing a couple fins and they were still in the pump housing. I used the boat for a few hours non stop and it ran at 165. Today before I went out I checked the oil and it was milky. I noticed the engine seemed to be sucking air more than usual after I cleaned the risers. Not sure if that has anything to do with water in the oil. Any tips? Thanks
alldodge
If the engine got hot enough you may have blown a head gasket or worst cracked the head. Suggest doing a compression test to see what shows up
