2000 60hp Johnson
Malia
I've been having problem trying to understand why my engine runs fine at the wash station and when I put it in the water I have a hard time making the idle climb? I've had the cylinders check and compression reads fine, I removed the VRO and changed the fuel pump, I've also changed the plugs?
Malia
Yes, Someone told me to test the coil first?
WernerF
A 3cyl. running on muffs but not in the water is typically one cylinder not firing. Check compression (no joke!) and check spark with a spark tester set to 7/16" gap.
Malia
What's a spark tester? I did have the compression checked. #1 - 125, #2 - 130, and #3 - 125
Malia
I found out what a spark tester is. Thanks, Anyway I did a spark test (old school way) by removing the plug and grounding it, there was spark on the individual plugs, no I am really confused.
WernerF
A spark jumping 0.030" in atmospheric air might not be sufficient in compressed mixture where higher voltage is needed. Jumping a 7/16" gap is the recommended test.
Malia
I'm sorry, I don't understand what you mean by jumping a 7/16" gap? My understanding of a spark tester is to check a spark plug and make sure it is firing. Are you saying it might be my computer brain? I truly don't understand.....Sorry and thanks for your help.
WernerF
No Title
A spark tester is an adjustable air gap that is connected to an ignition coil instead of a spark plug. It allows you to estimate if the voltage and energy of the spark is high enough to ensure proper ignintion of the mixture. In our case the gap of the tester is set to 7/16". If the spark is able to jump that distance, it is powerful enough to ignite te fuel.
Spark tester are commercially available or you can build your own.
Malia
Thanks, I have never seen anything like this before, I will ask the auto parts store and see if they have it and I will try it. Again....Thanks
