2000 50 hp carb filling with oil
pistonpants
I have a 50 hp johnson oil injected with low hours, every so often for some reason it won't start unless I spray fuel down the carbs to keep it running . It smokes like hell as if it is burning oil from the carbs. after you run it out it seems fine again.It also does this on start up on occasion. Anybody know whats going on? my oil tank looks like there is a spout for a return line but nothing is hooked up.
kjdunne
Re: 2000 50 hp carb filling with oil
There is no return line to the oil tank.
The hard starting sounds like maybe a clogged fuel filter, or dirty low speed jets in the carbs.
