maverick7687
- May 4, 2016
- 8
There seem to be a lot of these threads around lately.
Engine S/N: 0L658058
Thunderbold V Ignition
Don't remember the S/N of the carb but it is the factory 2brl with the Accel pump that has the 90 degree hook at the top and no check ball underneath.
I'm really wanting to bounce around some ideas and get some suggestions on what to check next.
I recently acquired this boat (2000 Bryant 196) and I am trying to get it waterworthy. It was stored outdoors with a slightly leaky cover and there was water in the engine bay when I picked it up.
I couldn't get it to start up so I replaced the spark plugs and the sensor inside the distributor. That did the trick. It will now start and run, it starts a little hard and will not stay running long (Average is 1 minute, sometimes 30ish seconds) then it dies like it's running out of fuel. Figured that should be easy, check flow to carb, maybe rebuild carb, done... Nope
Things that have been done already:
- New plugs
- Dist. cap/rotor
- Dist. sensor
- Verify fuel pump operation
- Rebuilt carb.
- New fuel/water filter
I had the carb apart twice, second time someone suggested recleaning the venturi section to no avail.
There was one time I swapped hoses from the boat tank to a portable fuel tank and let it run, it did the same thing a few times then ran for 5-10 minutes. Swapped back to the boat tank, ran for 2-3min and sputtered out again. Tried a few times with same symptoms as before. Swapped back to the fresh gas can and it wouldn't stay running like before. Could possibly need more time to run contaminated fuel out of the filter and get all fresh in but I thought I gave it enough time.
My next step is to keep trying the fresh can and connect a meter to the fuel pump wires to make sure it's keeping voltage (maybe oil pressure sensor intermittently cutting the pump?).
Pump seems nice and strong to me. Connected 12v to the pump alone and dropped a hose in a tank and pumped 5gal in about 7 minutes. Should be plenty to keep the carb fed, but I am a FI guy, never dealt with carbs.
It got too late and I couldn't keep starting it (live in the city, unfortunately, close neighbors) so I figured I would call it a night an do a little more research.
Any useful ideas from the experts?
EDIT: When engine starts to stumble out, pumping the throttle (I'm assuming because the Accel pump pours gas in) will make it pick back up and run for a short time.
- New plugs
- Dist. cap/rotor
- Dist. sensor
- Rebuilt carb.
