2000-2500 rpm vibration 5.0 L GL
mbram
We bought a different boat last fall. 04 Caravelle with a 5.0 L GL. It seems to have a slight vibration in a certain RPM range 2000-2500 RPM. I have had older V8 cars with things like this, kind of normal quirks for certain manufacturers. Is this normal?
gbeltran
How is the prop? Bent/nicked blades can cause vibration. How many hours? Gimbal bearing, ujionts, could be those also, especially if they weren't regularly serviced.
mbram
It is at about 380 hours. Prop is ok- it is worn. I need to get a back up and I could check it by switching it out.
mbram
I have paid more attention to the vibration. It seems to vibrate more when turning. Am I correct in saying this points more toward U Joints?
