2000 225HO Johnson trim troubles
Mr5Keepers
I have replaced both relays.. the trim unit wants to either NOT run or trim up ok ... and then try to trim both ways (just shakes like *&$9) with no change, the relays get REAL HOT.. sometimes it wants to run constantly..going either up or down? I have been towed in once and trolled in once!! The big motor would not crank becasue of the power drain when the trim was stuck on!
Going to get another set of relays tomorrow.?.?.?.
HELP!!!
THANKS in advance!!
Steve
71Windsor
Re: 2000 225HO Johnson trim troubles
check the connections on each wire to relay. check to make sure your toggle is not bad that you push to raise lower. just the other day mine quit. turned out the wires from that relay box down to the pump had a bread and was grounded out.
Mr5Keepers
all three switches are good.. all wires are making connections...
help.........
THANKS in advance!
Mr5Keepers
WOA>>>>> I was hoping for more info... the lack of responses is dis-heartening..
HHHEELLLPPPPPPPPPPPPP!
RRitt
why don't you try direct wiring the motor and see if it is sucking down too much juice.
you solve problems by divide and conquer. first step is to divide motor from wiring. then relay from wiring. etc etc.
