2000 150 Johnson, won't idle.
shuff
I have a 2000 johnson 150 and it will start and idle OK for about five minutes, slowly lose rpm and die. When the engine is warm it is a little better but not much. The only way to keep it running is to advance the throttle to around 1000 rpm and then it runs fine. Above idle the engine runs great. I have been told it may be a little slow in time. What are the specs?
dewley
Re: 2000 150 Johnson, won't idle.
doesn't Hays know the answer? Check with Gumby also, he is a boat owner now!!
