2000 150 hp Johnson outboard lower unit
Tim Faircloth
when removing the lower unit to get to the water pump is there anything I need to do on the top side of motor as far as the shift linkage or just remove lower unit bolts and it drops down
Thanks for Help
Tim
Chris1956
Honorary Supreme Mariner
On my '98 Johnny 150HP motor, you need to pull a clevis pin under the lower stbd carb and slide the linkage left to release the shift rod. Unfortunately, the linkage that moves is not obvious, so you need to look closely.
bob johnson
first things first....shift the gear case into forward while you rotate the prop by hand to assure the motor is IN FORWARD...this gives you the most access to the pin you need to slide out of the top of the shift rod..... you would pull the clevis pin and push the bard the pin when through away from you towards the port side of the motor.....this slides the "pin" out of the hole in the top of the shift rod!!!
that's all you need to do up top in the removal of the LU. on that model
bob
