2000 130 HP Johnson
Jerkalip
Appreciate any info on the record of this motor. Buying one. Owner says it has low hours and has never given him any problems. Any advice appreciated. Thanks to all of you "old salts" that spend the time answering all these questions. You guys help us sleep better at night. Really, I do appreciate what you do. God bless.
D
DJ
Guest
Re: 2000 130 HP Johnson
Great engine. Gobs of power, for its size.
Do the prudent checks:
1. Compression. All even (with 10 psi) over 100 psi.
2. Look at gear lube.
3. Running on the muffs means nothing. get an on water test, if possible.
