2000 115hp slips gear in right turn
Jdoom
I have a 2000 Johnson 115hp and when I am cruising and take a right turn the engine seems to slip gear into neutral. To continue I put the throttle in neutral and then back into gear and it works fine until I turn again. Usually it is when a turn is at cruising speed and not idling or going slowly.
Is this something to be concerned about or just an inconvenience of having an old motor? would like to avoid being stuck on water if I can help it.
Honorary Supreme Mariner
Sounds like the motor is mounted too high on the boat !-----------What is the model # of the motor and what is the height of the transom of your boat ?----------Not likely that gears are " slipping " in this case.
