2000 115 HP Johnson Bogging Down
Status
Not open for further replies.
Redland71
Hey Folks, I'm having issue with my 115 HP 4 cycle 2 stroke Johnson bogging down when I accelerate? The outboard will bog down then pick up multiple times before settling out. I've changed the plugs, squeezed the fuel bulb when it bogged down as well as replaced the fuel filter. Also, on the throttle I feel a shock sensation....I'm wondering if it could be a grounding issue related to the ignition?? Could it be to much oil mixing in the gas/fuel?? If anyone has encountered a similar problem or has a solution, I'd really appreciate your help. Thanks!
GA_Boater
i have a very similar pooblem with my 2000 Johnson 115 OIS
Welcome aboard.
Please read the Help Tip on top of the page - This thread is inactive. Probably because the poster has a 4 cycle 2 stroke. :confused: Start a new thread of your own with more information than you've given so far. We'll be glad to help.
Closed.
Status
