ankle-deep
Thread starter- Joined
- Aug 12, 2008
- 2
I need some clarification on the TPS setting on a 2001 200HP HPDI. The reference voltage is 5V across the orange and red wires. I disconnected the throttle linkage and backed off of the adjustment screw to fully close the throttle plates and set the voltage to .52V. The full range voltage, from idle to WOT, is .52V to 3.8V. My question is what do I set the voltage to with the adjustment screw once I have established the .52V at fully closed position? And also does the 3.8V at WOT seem low?
