200 evinrude needs help
burban
model#200849r serial#10001164 needs head gaskets ,and all head bolts .its mounted on a 22 ft bayliner ,what size prop should be on this i live in alaska -juneau. speed is not that important but still needed ,allaround good prop?it has none right now. any info or help would be great thanks ..
Hooty
Re: 200 evinrude needs help
Your best bet for a prop is your local prop shop. They will usually work out something where you try several different props until you find one suitable. <br />If not that, try here:<br /><br /> Props <br /><br />c/6<br /><br />Hooty
