Hi guys:
New to this forum and boating so bear with me...I'm a machinist, not a mechanic!!
I have a 1979 200 20hp that would not shift into reverse...had the boat out last weekend and forward is no problem (22.6kph with 2 adults) but when shifting to reverse with the mercontrol, nothing happens except when the lever is put against the stop it goes full FORWARD (??)
I had a tech with a little experience look at the cable and said there is no problem there, but said the prop should rotate freely in neutral (which is does not) and NOT go click click click (which it does).
We took the lower unit off and the main shaft turns the prop in both directions (he says it should not, but spin freely) and the small shaft (gear shift?) does not turn at all or go up and down, wheich he feels it should. He thinks it's a problem in the back section where the gears are. Stuck in forward?
Any ideas on this would be helpful, I think I will drop this off and have them restore it to normal operations. I just want to confirm what he told me is in fact accurate.
Thanks for the help!
