20 hp mercury
tumblebugm
run good until you kill it then will not start has got good fire and gas good compression 125 on cylinder what is my problem please help
12Footer
Re: 20 hp mercury
Check for a bad connection at the wire harness plug-in on the side (if pre1976).<br />These connectors are quick to fail. also,if quicksilver control equipped, check the ignition switch for the same corrosion on THAT end of the cable.
