2 wire accessory to 3 way switch
BlueDart
I'm installing a new depth finder and have an unused 3 way switch available.
Can I wire my 2 wire to this 3 way and if so what posts do I use?
Thansk
gm280
BlueDart, Not sure what you are referring to. Are you wiring an accessory with a positive and negative wire (being two wires) and a three position toggle type switch? If so then use the center terminal for the positive wire on the toggle switch and either of the other terminals that would go to the accessory. Then simply run the ground wire straight to the the ground source. Then your toggle switch will turn on and off your accessory circuit when you move the toggle switch from the center off position to the opposite of the wired side. If that doesn't make any sense, then let me know. JMHO
GA_Boater
Yes. Hook the fused 12V feed to the center terminal and either of the other two outside terminals to the depth finder. Flip the switch on and if you don't like up or down to turn on the depth, change to the other outside terminal.
BlueDart
Thanks for that as I wasn't sure I could use the switch I already had in the boat.
Your advice has made me confident with wiring the depth finder.
