2 stroke oil
hap777
I just bought a ski / fishing boat with an 115 hp Merc Tower of Power outboard. Does it matter what kind of 2 stroke oil it should run? What do u suggest? Thank you
lprizman
Whatever is on sale....those old beasts drink it....use good fuel and additive...de carb when needed... great outboards!!!
Push it and clear it out....they like to be run
Scott06
I ended up using amsoil 2 stroke premix oil on my older outboard smoked less and kept the plugs cleaner. You can use it a thin as 100:1, i never when that thin but had no issue going to like 60-70:1
achris
More fish than mountain goat
Spec is 50:1. If you NEVER run at full noise, then you can get away with less oil. But the second you run at WOT, it will NEED 50:1...
Chris..
To add to what Achris said. Your motor has a 2 cycle oil specification of TCW-III. Therefore use a 2 cycle that is certified as TCW-III. Amsoil is often not certified, and I therefore cannot recommend it.
Faztbullet
Ant TCW3 rated oil along with a dose of Quickleen, Ringfree, or CarbonGard additive.
robert graham
Mercury sells their own brand (Quicksilver) of 2 stroke oil at Walmart for a fair price.....maybe use that.....
