2 questions
Bgold85
Will the lower unit off of a 1974 85hp johnson fit my 1987 90hp johnson? Second, what would the 85hp be worth to buy. It runs all I really want is the lower unit.
emdsapmgr
You should verify that the upper drive shaft splines are the same between units. They have changed over the years. Also, the 87 lower has a sleeker design to the lower unit. The 74 is not as efficient through the water. Design changed somewhere around 80 or 81.
Honorary Supreme Mariner
The splines are all the same on these !--------The issue is that the 74 shifts to forward with a down motion of the shift rod.-----The 87 shifts to forward with an up motion of the shift rod.------Linkages must be altered in order for it to work.----Waterpump configuration is different too.--------Not for the novice.
