Ok guys i am very new but handy
, i took the Fam on Monday for a picnic at the lake and found water coming in from the transom bracket; i have read several threads and looks like the bellows are the problem. do i need to check other areas as well like (your input here is welcome)?
Our boat 1989 Bayliner Capri with a 5.0L OMC Cobra (Ford)
While looking under the drive i noticed a broken screw on the drain plug, (this is other question-drain plug is not the cause of leak), where can i get a new drain plug with a larger flange- the one i have the screws are too close to the opening in the haul and my believe is if i turn it around and drill new holes i will weaken the orifice and haul.
one more thing, the estimates i have seen for the bellows replaced are around $750, is this real or should i get my neighbors help and tackle the job myself using my seloc book.
thanks for the help in advance.
