Tao of Funk
Thread starter- Joined
- Nov 8, 2007
- 58
1976 70hp Evinrude
My 70hp fouls the plug when I run it at low rpm's for too long. I have checked wiring, plug type, ignition coils, and compression (I have fixed orifice plugs for the high and low speed jets on these carburetors and have not changed the opening diameter on the low speed orifice plugs...yet). The following discussion may not be the root cause of my problem but it is something I'd like to rule out.
My understanding is that the relationship between timing advancement and throttle advancement is critical for two cycle outboards.
Full timing advance is set to 17 degrees per engine placard. I read (somewhere) that the engine should achieve full timing advance at 4500rpm during throttle advancement when operating in the water. This is a tricky setting to check because it requires 2 people and the obvious engine-operating-while-cruising-on-the-water element. I have set the throttle cam per instructions (cam engages throttle roller at the proper mark) but this setting seems to be in vein since it does not necessarily ensure coordination between engine rpm and timing advancement.
Whenever I adjust one aspect of the cam engaging the throttle roller (forward or retarded ignition) I change another aspect of the timing/throttle advancement relationship. Is there another way to set this relationship up or is it paramount I check the timing advancement/rpm setting in the water while cruising?
Thanks!
GB
P.S. I don't have a tachometer so that's why I can't/haven't performed the on the water check.
Thanks!
GB
