I have a 1990 70 hp 3 cyl envinrude. Ive been havin issues with #2 coil always going bad with new coils CDI. I changed the PowerPack still same, issue took it to a Mech they repaced the voltage rectifier/regulator, still didnt help. I will run the boat for an hour (two trips one 30 min stop and 30 minute and stop) shutdown and hours later when Im ready to head out the motor is at two cyllinders again. I install new coil, Im back at.three. The connections seem ok. I cleaned and sanded all the coils ground and the ground bar. The Mech ran tests on the power pack everything seems.ok. I did notice today while boating the engine went from three to two cyl then it kicked back on to three.
Any help will be appreciated. Thanks
