Re: 2 black black spark plugs, 2 nice ones. What gives?
Compression is way too low on the bottom two.
Possible cause, check your fuel pump pulse hose between the pump and the crankcase for the presents of gasoline from a leaking diaphragm in the pump.
That will wash out the rings and the recirc hose will pull some of the extra fuel from one cyl into another and start washing out the rings there.
You need a rebuild, at least a re-ring, and possibly a fuel pump or a pump kit
