1st Time boat Owner! Please help the Idiot! haha
Androoshk
Hello all. I'm new here on this forum and I'll be in here a lot as i'm a first time boat owner... I have a 1969 Dorsett cuddy cabin w/ a 1968 volvo penta AQ130A motor (130hp). The current prop on there now is a 15" 15 P prop and the motor feels like it wants to go but somethings holdin it back...what would be a good size prop to go to? like a 15" 17 Pitch prop? The current prop has a chip or 2 in it so i gotta replace it....
rrhodes
Re: 1st Time boat Owner! Please help the Idiot! haha
What is the engine RPM at WOT (Wide Open Throttle)?
Your engine should be running between 4600 and 5100rpm Without those numbers we can't help you.
Other things may come into play as well. I had an AQ125A and it also felt like it wanted to go but couldn't.... I had to rebuild it. :) (Burnt Valves)
Androoshk
ok i'll find out that info today and post it on here. does it matter if the boat is in the water or should running it on my muffs be fine?
Starcraftguy1
In the water.You don't want high rpm's ever on muffs.
rrhodes
+1 You need to get your WOT RPM under load.
