1999 yamaha gp 1200 xl fuel problem need help
Dserrano
I'm new on jet ski, 1999 yamaha gp 1200 xl fuel problem. I cant get speed on the water, I go home took out my spark and when I try to start fuel come out for the cylinder but is lot of gas I don't know what is the problem. somebody tell me is the carburetor but I want to be sure is that the problem and what I have to do please help me
jafo9
a compression test is a good place to start. the number isn't really critical. somewhere 120-150's depending on the gauge. what is more important is that there shouldn't be more than a 10-15% difference among the 3 jugs. if the compression is good and the gas is fresh, then there is a good chance that all you need is a carb rebuild. there are little filters in the carbs that can get clogged, particularly with old gas that sat untreated. unfortunately, for that model the carbs are a little bit of a pain to get to.
I can't do a compression test because the gas coming out for the sparks thanks
