1999 Yamaha 90C alarm test
robert graham
trying to test my alarm horn to be sure it works, tried cranking on motor with stop lanyard removed, but no horn. any easy way to get the horn to sound just for test? Thanks for any help!
99yam40
Re: 1999 Yamaha 90C alarm test
I believe grounding the pink wire that goes to one of the temperature switches on the head will bring in the over temp alarm when the key is on. At least it will on my 99 40hp. the other temp switch is for telling CDI that the motor is warmed up.
robert graham
Thanks, so do I just unplug that pink wire from the switch and then ground it to get the alarm horn? electronics is my weakness...Thanks Again!
rodbolt
yep, ground the engine side of that pink bullet connector not the switch side.
