retooferab
- May 30, 2007
- 10
Please pardon if this has been answered. I've been reading and reading and haven't found an answer.
Motor: 1999 Yamaha 225 V-Max ox66, (oil and fuel injected)
Boat: 1988 Ski Centurion Warrior Barefoot Comp (20 ft, 1100 lbs w/o motor)
Symptoms:
Smokes excessively at idle and just off-idle.
Runs rough/stumbles until about 2200 RPM.
Idle sometimes rumbles down to 4-500 RPM.
NO problems starting, or running at higher RPM's/speeds.
Problem:
Makes speed maintenance a real pain for little skiers in the 12-20MPH range. Also difficult to teach technical starts like backwards deepwater barefoot.
Tried:
Paid local Yamaha tech $400ish to replace the oxygen sensor and "solve the problem" which may have involved other tests... but no substantive work. It now runs as bad as ever; no improvement at all.
After looking at a friend's Yamaha manual, I was unable to pinpoint the problem. After studying the Clymer manual, tried to test for Vapor Separator Tank flooding which listed the exact symptoms I'm having. It mentioned the motor would stumble because it's given excess fuel (through flooding VST) and then burn it efficiently at higher RPM's... The test was to disconnect the vent hose on top of VST, squeeze the primer bulb, and see if any fuel exited the vent hose fitting. Since the diagram was slightly untrue to my motor, I had to guess at the fitting... but I tried two with no hint at all of fuel seeping out.
Now what?? I love my boat, my motor and my money... don't want to flush more away at dealer for no improvement. (They did NOT water test it and have no means to do so near their shop.)
What other information is needed for this diagnosis/solution?
Thank you so much in advance!
Symptoms:
Problem:
Tried:
