FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
cylinders 1 and 4 fire from the top coil and 2 and 3 from the bottom.
rules out a coil.
did you drill out and remove the brass plugs that cover the air fuel screws and clean that passage?
did you reset all shutters with a 4 channel manometer?
why check timing, its not adjustable.
its either where it supposed to be or broke.
no moving parts,other than a flywheel and the TPS really involved in timing once the engine is warmed up.
I would test leakdown then go fix the carb issue.
