scb1712
Thread starter- Joined
- Jul 25, 2011
- 105
Hi all,
Ah - the joys of boat ownership continue. First, i have a 1999 Volvo Penta 3.0l GS-PEFS engine. Had some overheating issues last year but all of those are now resolved and she's been running pretty well so far this year.
I know that the carb needs a rebuild as i don't think the high speed jet is working optimally as she bogs a bit when you give it full throttle. While not ideal, it has certainly been manageable and hasn't really caused any performance issues even when water skiing or tubing. Generally, when you give it full throttle, it would bog momentarily, and then get up and go accellerating smoothly up to about 4500 rpm.
However, this weekend it seemed to start a bit of a mis-fire. The engine sounded "off" and she wouldn't accellerate normally. After shutting it down for a few minutes, it started up fine. However the misfire appeared intermittantly while we were trying to ski, as it would bog more noticibly and not accellerate smoothly after the initial bog. Eventually after a rest and some easy running, she ran normally for the trip home.
Could this be an extension of the carb problems? Perhaps some bad gas or should i be looking elsewhere? Also - i've read in similar threads that i should consider changing out the plugs, wires and cap. Can i use parts from the local automotive store, or do i need to get Volvo ones for 6x the price?
Thanks!
Thanks!
