1999 VMAX 200 OX66 Part found in Fuse Box??
skeeter10
Hello, I opened the grey fuse box on the starboard side of my motor and out came a small black electrical connector with 4 siver prongs. Please see attached pics. I could not find a place for this part in the fuse box. I assume this is a spare part. Can anyone confirm what this part is for? :)
Thanks
rodbolt
Re: 1999 VMAX 200 OX66 Part found in Fuse Box??
its actually supposed to be plugged into the fuse holder, its for the battery isolator circuit.
post a pic of the fuse holder, its located under that plastic cover.
the big rubber block.
skeeter10
Rodbolt, here is a picture of the fuse block. I pulled it out toward the camera so you could see. The loose piece appears to be identical to the two pieces that are inside the block.
rodbolt
both fuses are in place, you simply have a spare.
skeeter10
Thank you sir. You are much appreciated here in Austin Texas!
