1999 OMC johnson 4.0 points?
fishimpaler
where are the points located, and how do i access them, i already pulled the flywheel.
thanks
Daviet
Re: 1999 OMC johnson 4.0 points?
If you are talking about a 1999 4 hp johnson, I beleave it uses a sensor under the flywheel instead of points.
ondarvr
What problems are you having?
tx1961whaler
No points.
convert
Rick.
Or for that matter make certain your kill switch lanyard is in place. Best of luck. Rick.
