1999 johnson tilt cylinder
bassquest
I have a question about my tilt cylinder. It will tilt all the way up fine but when you start to come back down, about half way to the trim cylinders, the engine starts jumping until it gets to the trim cylinders. Now while you tilt it down and you pick up on the fin above the prop it will not do it. I've been told that I have air in the system and I have done what I was told to do to get it out. Replaced the fluid in the reservoir twice and have trim the motor all the way up and down numerous times and it still does it. Had a guy tell me that it could the ball in the check valve gone bad. Idk Any help or advice would be appreciated. Thanks
Chris1956
Honorary Supreme Mariner
Usually greasing the tilt rod and bleeding the system will fix that. Joe Reeves would recommend some air pressure on the PTT reservoir to aid the bleeding process.
Since you replaced the PTT fluid, I would suspect you still have some air in the system.
boobie
Try greasing the tilt tube bushings on the mounting brackets where the motor tilts up and down.
