I have a 1999 Johnson 25 hp outboard that just started dying upon acceleration. It restarts as soon as you turn the key. You can start opening the throttle slowly, and the engine runs perfectly. Ease the throttle open and when the boat reaches around 7 mph, the engine suddenly dies. No sputtering, just dies like you shut off all fuel or turned the key off. First time it did it, i tried opening the throttle to full and it suddenly died. Did this several times, it kept dying. I then opened the throttle very slowly and after a little while, it was running wide open, and ran full speed for 20 minutes back to ramp. I shut it down there, and reopened throttle fast, and everything was ok. Next time out, could not get over 6 mph, no matter how i opened the throttle. Before it dies, engine runs perfectly. Checked fuel lines and all seem solid. Checked filters in tank and on fuel pumps, all clean. Fresh gas. Mix my own fuel as i did away with the VRO a couple of years ago. I'm stumped. thanks
