Kashwakamak
Thread starter- Joined
- Jul 15, 2019
- 8
Have had this boat for 9 years. 7 years ago I replaced oil pump, power pack, plugs, inductive spark plug leads, cleaned and adjusted carb floats, and added a fuel/water separator. I run fuel stabiliser in it all the time so I never have to worry about gas sitting in it over the winter untreated. Runs great, normally...
Two weeks ago I was running at half speed when I noticed the engine start to make a light "knocking" sound. I docked and checked and appear to have spark on all four plugs. Replaced plugs. Checked to see which cylinders were firing at idle tied to the dock. The port side cylinders do not seem to be firing as when I remove both of the leads the engine continues to run with no noticeable RPM drop (although there is spark). When I do this with the starboard side leads, the first one removed (top) drops the revs by 1/4, then removing the second lead causes the engine to stop running.
Put all four leads back on the spark plugs, fire it up and it seems to be idling fine. I spray gas into the starboard side carbs, top first, and the engine starts to bog. The same happens on the bottom. When I do this on the port side, nothing changes. I hold my hand over the carb intake on the port side carbs for a few seconds while the engine is running and I get plenty of fuel coming out when I release my hand.
I have changed the fuel output from the VRO pump to redirect port and starboard flow to the opposite fuel manifold rails and there is no difference in performance. When I disconnect the leads, it still appears as though only the starboard side is running.
I have done a compression test and the cylinders are all within spec with the largest difference being 12 PSI between cylinders. I checked the engine temperature after running at idle for a few minutes with a laser temperature gauge and they all seem to be running at 57 to 65 degree's Celsius.
I just replaced the power pack and am still having the same problems... (expensive mistake). There are two coils on this motor; the top coil feeds the top two cylinders, port and starboard, and the bottom coil feeds the bottom two, port and starboard. I do not think the problem would be coils, or the power pack. I am using inductive spark plug leads and noticed one of them had a split on the insulation and replaced it with one of the old ones.
A local guy said that the carbs feed the opposite side cylinders on this motor, yet when I spray gas into the carbs on the starboard side, the engine bogs. The port side does nothing and this is the side where I can unplug both leads and there is no difference in the RPM's. Whereas if I unplug both starboard leads the engine stops.
Would it make sense that I could possibly have a fuel problem on both carbs on the port side?
As well, when I do take it out to see if it is working at high speed I am able to get up on plane quite easily. This makes me think I am getting "better" spark or fuel flow at higher RPM's, but still hear the faint knocking noise and it is not even close to it's regular top speed of ~48 MPH.
I have a new water/fuel separator filter but have not replaced it yet.
I look forward to any thoughts and thank you in advance!
Cheers,
Jeff
Cheers,
Jeff
