1999 Johnson 90 hPa trim pump leak
Macca1500s
Hi all how does Tis sound, I had my boat serviced , it's new to me so I always pay the professionals to do a full service before I get carried away using it
Anyway when I got it back from the mechanic he asked had the trim system been leaking, as the boat is new to me I couldn't say either way
So on getting it home I noticed it was in fact leaking, I could have called up the mechanic but at the risk of having to pay more money I thought I would investigate myself
The previous owner had replaced the trim pump motor and apparently re used the o ring seal as there was a new one in the side pocket of the boat
So ah ha I thought I'll swap out the seal as it appeared that there is where the oil was leaking
So today I dug into it, trimmed the motor up fully, flipped the stay into position, released the manual release screw
And removed the trim position switch, I reckoned there was enough slack in the trim motor cable to allow me to remove it
Moving along I saw that the trim oil fill cap screw driver slot was fairly knocked around so decided to make sure I could remove it before going any further
When I did, there was a huge amount of air pressure escape then a significant amount of oil maybe a pit more than half a cup
My understanding is that with the Rams fully extended you fill the oil close it off and the up and down the trim a few times to bleed it, continuing the process till all the sound of air has gone and the system works smoothly
So I took out the motor mounting screws but couldn't move the motor, I started to think of getting something to tap the motor, but then thought ,I wonder if the mechanic serviced the unit on his bench and over filled it
So I put it all back to gather and went through the process of filling the oil and bleeding.
And early days yet and I may be kidding myself but no leaks
So I wonder if being over filled it was presurizing it's self and the oil was forcing it past the seal
How does that sound. Reasonable???
Macca1500s
Ok been sitting for a couple of hours now, I've gone out a few times and powered the trim up and down, no leaks
Tomorrow will tell
Chris1956
Honorary Supreme Mariner
Pressure an build up in those units, if they are not properly bled.
I would doubt the mechanic looked at the PTT unit, as they want to do the minimum you would accept, which is likely plugs, timing and gear oil.
Macca1500s
yep i agree but in this case one of the trim rams had started to spit out a seal, protruding from the assembly, so he had to fit a seal kit
also he cleaned the corrosion (minor) off the unit and repainted it, he,s generally very good
but having done what i have done its not now leaking , so i can only assume he over filled it
boobie
Keep on checking it the next few days and see what happens.
Macca1500s
Oh well good try by me, still leaks but now I know it's the pump motor mounting and not the Rams.
So I guess I have to take it off and do it properly
Last time I couldn't get the motor off, I removed the 4 bolts and it didn't seem to want to lift off, is there a step or rebate
And do I just have to try harder or gently prise it off
Thanks
