1999 johnson 50hp j50pleea timing issue
fordwheeling250@yahoo.com
I purchased a used boat this year and from day one it was hard to start. It had good compression and spark and then on the 4th of july it lost spark completely. once i got the manual i did some testing and traced it to the timer base. I replaced it, the stator(due to cracking and goo),and the coil pack. The timer base instructions say to time it after installation. We took it to the lake and ran it at 5000rpm under load while testing as the manual says. The initial timing on number one cyl was at 10deg and the book says it should be at 18-20 degrees we adjusted the linkage shorter until it bottomed out in the ball joints and the best reading was at 16deg. This doesn't seem right to me. should it need that much adjustment? and is there another way to bring it in closer to the 18-20deg?
Thanks
