1999 Johnson 4hp prop slipping??
County09
I have a 1999 Johnson 4hp motor and when it's full throttle it feels like the prop is slipping, it will rev up real high. I checked the shear pin and it's in good shape prop is also in good shape. I just can't figure out what is wrong. Thanks
F_R
Honorary Supreme Mariner
There is a rubber ring in the prop, and inside that rubber ring is a metal hub to fit the prop shaft and drive pin. It is designed for the hub to "hop" a notch in the rubber if you hit an underwater obstruction. The rubber may be shot. Push the adapter out for a looksee.
Or, worst case scenario, the splines where the drive shaft enters the crankshaft may be rusted away.
Crosbyman
cavitation maybe.... is this a short shaft motor on a 20 inch transom....
is this a new problem ??
County09
I will check the prop. I don't believe it is cavitation because it does the same thing in a tub of water too. When I bought the motor it had this problem. The motor runs great at half throttle. Thanks
County09
F R, I cannot find the rubber ring. Would it be visible as soon as I took the prop off?? Thanks
boobie
Go to shop.evinrude.com and look up your motor. You'll see the ring that F_R is talking about. It's in the prop.
