1999 Johnson 175 Troubleshooting - Just can't pinpoint the problem
reiddo1
I tested a couple different connections. so plug wire ------>tester--------->clipped to spark plug that was still grounded in the block. I tried this multiple times with multiple different gaps, small gaps and large gaps. (On two different sides of the motor, two different plugs) I even tried with it on the bolt again. I was unable to produce any spark. No spark at all. What should be my next step for troubleshooting the electrical issue I am apparently having?
If you have not already tried to start the engine with the wiring harness disconnected, you should. There may be an electrical contact issue in either the harness or ignition switch.
bob johnson
try this......take all the plugs out.....and just ground your tester to a bolt on the block thats clean with no paint... and install the tester in the closest spark plug boot...make sure it is snapped down on the tester(inside the boot).......then crank the engine.... your starter system may be weak..... if you do get spark like this...then you know your starter is too weak to get the rpm needed when the motor is under compression!!......if you don't get spark...then you are looking at electrical ignition issues.....which can vary....if you have the book...there is a progression of tests one after the other to pinpoint the cause or causes
bob
Chris1956
Honorary Supreme Mariner
If you sprayed starting fluid into a cranking motor and she did not fire, you either have no spark or no compression or both. From what I have seen, your spark is at least suspect.
I would recommend you purchase a factory service manual and study it, or take it to a OB shop for repair. Disconnecting the wiring harness is not the next step. CDI Electronics has a troubleshooting procedure on their website. You might take a look at it.
reiddo1
My 2000 Johnson 150 was exhibiting the same characteristics; mind you it had been underwater for 4 hours several days before. Sometimes I had spark and it ran but other times I could crank it forever it seemed and it would not fire. After disconnecting the harness where the main control wiring harness is hooked into the engine and jump starting it, it started right away. Replaced the harness and after that it ran like a dream.
Chris1956
OK, so your harness was shorted. It happens, and he will need to sort that out. However, when you disconnect your harness, you have no reference voltage to the voltage regulator or the OMS pump. Any idea the effect of that?
Faztbullet
There will be no effect to regulator as it will be off if OEM or charging if aftermarket and OMS pump is not electrically operated just the alarm sensors,no voltage ,no alarm or check engine function. This is how thousands of boats are stolen yearly, unplug harness ,jump solenoid and away we go...
reiddo1
There was certainly no effect on mine!
