reiddo1
- Jan 17, 2012
- 166
If you have not already tried to start the engine with the wiring harness disconnected, you should. There may be an electrical contact issue in either the harness or ignition switch.I tested a couple different connections. so plug wire ------>tester--------->clipped to spark plug that was still grounded in the block. I tried this multiple times with multiple different gaps, small gaps and large gaps. (On two different sides of the motor, two different plugs) I even tried with it on the bolt again. I was unable to produce any spark. No spark at all. What should be my next step for troubleshooting the electrical issue I am apparently having?
