Every once in a while, when I go to start the motor, I get nothing when I turn the key. I check and find that the starter pinion is up and jammed under the flywheel (the teeth are not aligned and engaged). I use a wrench and turn the starter pinion, and it drops down. Then the motor starts fine. This will be REAL inconvenient (and potnetially dangerous) if it happens in rough seas and I have to take off the engine cover and repeat this procedure.
Battery is fully charged.
Is this symptom a lubrication problem? A starter ready to fail, in need of replacement? What should I do?
Please help!?
Please help!?
