robert.tadefa
Thread starter- Joined
- Aug 20, 2011
- 6
at 4.5 RPM I lost power and would not restart. Then next couple of days, started right up. I let it run about 20 minutes in idle before taking it out again. Died again. Now, after sitting for a while, it will try to start, but seems not to have enough power. If I use tilt and crank a couple of times unsuccessfully, then there is no power at all.
I replaced plugs, wires, connections, fully recharged battery.
Someone mentioned this could be the stator. Someone else said solonoid.
Suggestions?
Suggestions?
