Captain Jeff
Thread starter- Joined
- Jun 15, 2005
- 161
1999 Johnson 115 (60 Degree V4). I was running it in the driveway and noticed the starboard cylinder head and thermostat housing was hotter than the port side. I checked with a non-contact infrared thermometer and found the port side was running around 105-108 F and the starboard was running between 130-143 F (too hot to touch for long). The lower cylinders on each bank ran cooler than the upper. This is after running 5-10 minutes between 900-1,500 RPM on earmuffs.
There is a very strong telltale stream. I replaced the thermostats two years ago. The boat has been used 95% in freshwater. I just replaced the complete waterpump with an OEM pump kit but I don't think that has anything to do with it. This doesn't seem normal, please let me know your thoughts. Thanks!
